heatsinker
- Feb 4, 2001
Currently I have two Cisco 2500 routers stacked on top of each other connected via both Serial and AUIs using Ethernet (through a Catalyst switch) and I'm having trouble pinging either router using the Ethernet interfaces. I'm pretty sure the IP addresses and subnets are correct and they're definitely not shut down, so it's not that. Basically they have no connectivity between each other, except through the serial connection. Is there something I'm missing here?
