router and Q3A question
New Start
I just installed a Netgear 4 port router that my friend gave me to use as a simple firewall.
I noticed that after installing the router Q3A seems different. Now, altho the count will say 200-300 in 20 seconds of waiting, it only lists 10 or 20 servers, and all of those except a couple are very high ping.
The router is set with all default settings, everything else works just fine.
What to do?
it might have something to do the ports on the router not being open. the ports that need to be opened can be found here
also, make sure you don't have any filters on the server browser. that might be limiting the number of servers you are seeing.
