Ive been trying to find any opinions on routers out there that would be good for lan gaming.
Currently I have a relatively old linksys wired router and it doesnt seem to be able to handle heavy traffic. Whenever I have less then 6 pcs playing games at the same time, its fine, but when I add a 6th or more, the ping spikes and then the I loose the connection all together. It seems like the router just cant handle the load.
What Id like is a quality WIRED router since I have no uses for wireless, but if the only good options are wireless as well, I could deal with that.
a 4-port variety of router is all I need, just one taht is reliable at handling high traffic of the gaming variety. Any suggestions would be very helpful. thanks.
