Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I'd recommend against going with rounded cables in an SFF. The reason is simply that rounded cables are a bit more bulky when you are trying to route them in an SFF box. I find the flat ribbon cables are easier to manage in my SN85G4 than the rounded IDE cables I originally started with. Also, one of the cables that goes to the Optical drive is already supplied (pre-routed) and its a combination flat/shredded cable. If you install a short IDE rounded from the front of the mobo to the back of the hard disk, it will be obstructed by the drivecage. Underneath the drive cage is a flat ribbon cable tie down that makes it quite orderly.
