Well as the Title says, I was wonering if dremel bits will work wwith a roto-zip... Bought a roto-zip a month ago to cut some wood and what not (to build a pen for my puppy) and was wondering if I can use it to use Dremel bits with IE cutting disks.. As for $$ is somewhat tight, and I would rather spend the $40 or so on new parts for my comp. Anyone have any exp. with this? I need to cut a 120mm blowhole in the top of my case to mount my rad...
