rotating the 2005FPW
c0ex
How do you rotate the 2005FPW. Mine came today and i cant move it 90 degrees.
Why not? It twists freely. Perhaps your cables are getting caught, or you may have to raise the display up higher to allow it to rotate without hitting the desk.
i turned it the way it is suppose to turn. Now how do I get the screen to turn with it. The whole moniter turns the but the screen still says sideways
right now im using my onboard video until xmas when i get my xfx 6800
It doesn't auto detect, and it's not supposed to.
In the nVidia Display drivers go to the NVrotate section. Then select the appropriate direction to rotate your desktop.
:rolleyes: Heres how to do it if you have an Nvidia based graphic card: Rite click on your desktop then properties then settings then advanced then type of video card (Example: GeForce 5XXX or 6XXX or 7XXX) then NVRotate. Do this before you rotate you monitor. ;) :D
dsc220:
there is a button at the back of the stand, at the very bottom. It releases the monitor after it "clicks" in the lowest position
