HardDrugsUser
- Nov 12, 2007
I am planning to build a media center PC with AMD 780G chipset which has HD 3200 GPU.
See the asus board:
http://www.asus.com/products.aspx?modelmenu=2&model=2252&l1=3&l2=149&l3=639&l4=0
Last time I had an ATI card it was year 2000, so I will be happy if you can help me with a question I got about ATI card and Catalyst Software.
I need to know if it is possible to do a [Rotate Display] on these cards.
In Nvidia control panel it is a standard, but after doing a search in Google it seems that ATI cards have problem rotating the display.
It is absolutely critical for me to be able to rotate the screen/display 90 degrees and keep this setting permanently.
Thanks
See the asus board:
Thanks
