Rosewill RNX-EasyN4 port forwarding.
RyanGSams
I have done this multiple times before for my Xbox and PS3. But now trying to add another port and it only refreshes the page without saving any of the information I input into the fields. I have done it multiple times and even restarted the router with no luck. What else can I do to try and get it to work without completely doing a router reset?
Any help would be appreciated.
Sounds like a config problem.
Backup the router.
Wipe.
Reconfigure, if that doesn't work or you bork up the config.
JUst restore you backup.
Wipe as in restore to factory default?
Edit: Did a factory reset and went straight to the port forward to configure the ports and it still won't go through.
I'm having the same problem. Just purchased a RNX-N4PS router, everything is great except I cannot get the port mapping or the port forwarding to save. It lets you click the checkbox to turn it on, but when you try and add a map to it, it doesn't seem to save, just refreshes the page with no changes made.
Tried it with uPnP on and off as I saw that as a suggestion somewhere - no change. Tried loading from the initial config file after setup as well as a factory reset and doing everything from Step 1 again - still no change.
Have placed a support request to Rosewill. Hoping to hear back from them soon.
Curious to know if the OP resolved the issue.
