Abraxas601
- Nov 11, 2011
Just replaced my HAF X 942 with the Rosewill Blackhawk Ultra. Here's some photos,
Definitely a deeper case
Here's a couple photos of everything in the HAF and then the Blackhawk,
HAF X 942
Blackhawk Ultra
Notice the radiator for my H50 is completely concealed in the forward 5.25 bays on the HAF. Due to the Blackhawk being a lot deeper it just barely made it to the back edge of the bays.
Speaking of the 5.25 bays. There are 4 of them. The bottom three also have holes for a fan. So top bay for a DVD and bottom three for a fan if you don't have anything else to put there.
Here's a great little piece of hardware that I've never seen before.
So with the HAF X I had just about every fan I could put in it. This also meant a jumble of fan wires to manage. The Blackhawk comes with a pair of little boards that allow you to connect 5 fans through a single molex connector.
Finally, here's the side panel. It allows for a combination of fan configurations and sizes. You can have 9x120mm fans. All the circles are mount points with rubber grommets.
I would say this case overall is more function and less flash when compared to the HAF X 942. It's not as "cool" looking and you lose the nice acrylic window for showing off your spiffy parts.
LOTS of metal and no sharp edges. The only plastic is the fans and the corner trim. It comes with 8 fans and has additional fan mounting spots all over the case.
Someone really did put a lot of thought into this case. There's always room for improvement but coming from Rosewill, this is an incredible step up for them. I'm very happy with what I got for the price.
HAF X 942
Blackhawk Ultra
