Hello everybody
I've been asked to diagnose a possible failure in the HDD of one server and I'd like to get a little light on this topic.
What I've been told is that there's an unusual flashing in the server's leds, and one of the possibilites is a bad disk drive. I also been told that the server has not diagnotic tools installed.
I only have ssh access since the box is on a remote location.
This is an HP PROLIANT DL160 G5 S/N 2UX84600HG server:
[root@cdr ~]# dmidecode --type system
# dmidecode 2.10
SMBIOS 2.5 present.
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: HP
Product Name: ProLiant DL160 G5
Version:
Serial Number: 2UX84600HG
UUID: 808ADE18-D21D-B211-8000-00215AEB1A94
Wake-up Type: Power Switch
SKU Number:
Family:
Handle 0x0036, DMI type 32, 20 bytes
System Boot Information
Status: No errors detected
This is a linux server, but I'm not sure about the distro (I mean, it accepts redhat commands, but I can't get a distro name like fedora or centos):
[root@cdr ~]# cat /etc/redhat-release
Linsys Communications Platform v6
Any thoughts about the version?
Kernel version should be:
[root@cdr ~]# uname -a
...2.6.32-4034.lcp6.nm.x86_64 #1 SMP Sat Nov 13 02:24:19 CST 2010 x86_64 x86_64 x86_64 GNU/Linux
I obtained this output form the server:
[root@cdr ~]# sudo fdisk -l
Disk /dev/sda: 2000.0 GB, 1999999336448 bytes
255 heads, 63 sectors/track, 243152 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x000883d2
Device Boot Start End Blocks Id System
/dev/sda1 * 1 64 512000 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/sda2 64 243153 1952611328 8e Linux LVM
Disk /dev/dm-0: 53.7 GB, 53687091200 bytes
255 heads, 63 sectors/track, 6527 cylinders
Disk identifier: 0x00000000
Disk /dev/dm-0 doesn't contain a valid partition table
Disk /dev/dm-1: 7348 MB, 7348420608 bytes
255 heads, 63 sectors/track, 893 cylinders
Disk /dev/dm-1 doesn't contain a valid partition table
Disk /dev/dm-2: 1938.4 GB, 1938405982208 bytes
255 heads, 63 sectors/track, 235664 cylinders
Disk /dev/dm-2 doesn't contain a valid partition table
Should I be concerned about the "Disk /dev/dm-2 doesn't contain a valid partition table" messages?
On the other hand, I've tried to obtain the output of a diagnostic command but it seems the hardware doesn't support it.
[root@cdr ~]# smartctl -a /dev/sda
smartctl 5.39.1 2010-01-28 r3054 [x86_64-unknown-linux-gnu] (local build)
Copyright (C) 2002-10 by Bruce Allen, http://smartmontools.sourceforge.net
Device: LSILOGIC Logical Volume Version: 3000
Device type: disk
Local Time is: Fri Oct 11 12:22:11 2013 CDT
Device does not support SMART
Error Counter logging not supported
Device does not support Self Test logging
I get the same output for /dev/sda1 and /dev/sda2.
I know this is not a linux forum but any light on this matter would be amazing.
Is there any other info I should check?, any output of a command that could be useful to determine wether is a failure or not in the disk(s)?
Many thanx in advance for your valuable help!!
# dmidecode 2.10
SMBIOS 2.5 present.
System Information
Manufacturer: HP
Version:
SKU Number:
Family:
Device type: disk
