So I started my new build with this thing and I had a couple of questions.
1. I am running a single graphics card (1660Ti) and was thinking about installing it in the 2nd PCIe slot. All 3 are listed as PCI 16. That would bring the exhaust fans about 3 inches from the bottom of the case (Define R6). However putting it in the first slot puts the back of it close to the CPU and I'm worried about excess heat. Which is the better option?
2. The NVMe cover had some sort of sticky tape on the underside with a "please remove" film. Is this some kind of heat dissipation material? It feels like an adhesive.
