RocketFish Case+Lian-Li CD Bezel?
GigantoR
Has anybody installed one of the Lian-Li aluminum drive bezels in the RocketFish tower case? I know the RocketFish uses plastic clips to secure the optical drive bays and don't know if this would fit right.
Well, for anybody that wanted to know (which evidently isn't that many people lol) yes. You can use the Lian-Li bezels with this case. You can simply push the driver farther back and use the standard slots for mounting screws. The plastic clips will not engage, or you can drill them out and remove them.
