Can anyone give me an idea what the back of this would look like?
http://www.bigfootcomputers.com/Mer...ROD&Product_Code=5008ELEC&Category_Code=600.1
Originally posted by jnex26
I'm just guessing here but
probably 4/2 spade connectors or Solder pins.
2x for Light.
2x for switch
Originally posted by STRESSTEST
As far as your reset switch goes... Are you talking about using this toggleto replace that one with but still use it to reset? Im a bit confused on this. Or did you mean that you would remove the reset from your case bezel and use that position for this switch to control your lights?
Originally posted by dewhite
That won't work, unless you intend to use your CCFL for transmitting ship-to-shore morse code.
An ATX reset switch is a singlepole, singlethrow momentary pushbutton switch. You need a toggle switch which will stay actuated (leaving your light on, for all to enjoy) until you return it to the open, or "off" position.
