Roccat Kone+ Issue
Paradocks
My Kone+ doesn't start along with Windows. As I log in to my desktop, the LEDs remain off, and moving the mouse doesn't cause the cursor to move. However, as soon as I left or right click, the mouse springs to life - LEDs come on, and within a few seconds I'm able to move the cursor. I don't believe it's a USB power problem, as I have switched around the ports it's connected to no avail. It might be driver related, but I honestly can't figure out how to completely remove the drivers from my computer - so if you know how to do that, that'd be a good thing to try!
Luckily for my American ass, it isn't a big enough issue to warrant shipping overseas for repair, at least I don't think... Any ideas?
I use the Kone+ , & fortunately , don't have that issue you seem to be having . It seems as though there is a driver conflict of sorts , something that is preventing your Kone driver from starting with Windows .
A reinstall of the Roccat drivers may help . I use Revo Uninstaller for uninstalling programs . For me , the Add & Remove Programs in Windows doesn't do a thorough enough job . You can find Revo Uninstaller here :
Revo : http://www.revouninstaller.com/start_freeware_download.html
The latest Roccat Kone+ driver here :
Roccat Kone+ : http://www.roccat.org/Support/Gaming-Mice/ROCCAT-Kone-/
Thanks a ton for the response. :)
So far so good - but then again, it's an inconsistent problem. Hopefully I won't need to pester you in the future!
