This is my command line: robocopy d:\ e:\ /mir /l /xd $RECYCLE.BIN
And this is the output:
I've tried D:\$recycle.bin, "$Recycle.bin" and so on, but it will not exclude the directory and keeps failing on it. So how do I exclude this directory and it's subdirectories? I've searched google and seen people with similar problems but I couldn't find a solution.
edit: Just figured out I can use /r:0 to eliminate the retry and it will continue to the rest of files, but I still want to know why it isn't excluding $recycle.bin ...
Uhg, NVM, it's because powershell treats $ as a variable indicator..doh.
Code:
jgentile@quadbox●~\powershell►robocopy d:\ e:\ /mir /l /xd $RECYCLE.BIN
ROBOCOPY :: Robust File Copy for Windows
Started : Thu Jun 16 12:46:00 2011
Source : d:\
Dest : e:\
Files : *.*
Options : *.* /L /S /E /COPY:DAT /PURGE /MIR /R:1000000 /W:30
4 d:\
0 d:\$RECYCLE.BIN\
New Dir 1 d:\$RECYCLE.BIN\S-1-5-21-2647135948-198952911-1883998332-1001\
New File 129 desktop.ini
1 d:\$RECYCLE.BIN\S-1-5-21-903913729-2069915181-891838863-1000\
Older 129 desktop.ini
2011/06/16 12:46:00 ERROR 5 (0x00000005) Scanning Source Directory d:\$RECYCLE.BIN\S-1-5-21-903913729-2069915181-891838863-1002\
Access is denied.
Waiting 30 seconds...^C
