mycomputersucks
- Oct 31, 2001
Hey all,
I have about 20 users who currently share workstations. It is shift work so we use roaming profiles so they have access to their personal data from any workstation. however, we have a problem. people have screwed up their profiles by installing software/etc to the point where they get different results on each workstation. IE, apps will run fine on one machine, but spit out errors on the next, and the results are different for each person.
now, we are going to wipe all the profiles and start again since we just got approved for a hardware refresh. How can we set this up again? I'm thinking we could do either a shared login or even local logins, but that would cause an issue w/ outlook. We have a shared network drive which could be used for personal data and i believe we could use the network drive to host the outlook pst files, i think? is there a way to have a shared login but have outlook 2007 load separate profiles in order to keep their email data separate? same issue with all the autologin stuff. with shared logins i don't want people saving favorites or having passwords saved, that stuff can be kept on their network drive (which would have individual logins, i'm thinking).
I'm not an Active Directory/sys admin guy. any advice?
