RMClock Vs. PC Probe 2
pantzer
Ok, this is very weird, I was reading your guide on overclocking, because I am interested in doing it at some point, so I downloaded the RMClock suggested to check my core temp.
On RMClock its saying my core is at: 14.2c under minimal load.
On PC Probe 2 its saying: 40c at the same time.
I don't think my room is cold enouph for the CPU to even be at 14.2c when its off. Its currently 76f in my room. How do I make RMClock get the correct temp?
AMD AM2 X2 4400+ with a zelman 9700 LED. I used the zelman thermal grease.
Its not OC yet, I was worried about the fact I was going upto 46-50c when running at load already. (using pc probe 2)
I think I figured out what its doing, if you add the two cpu temps together you get one that is 2c less then pc probe 2.
