i found an error thru HD Tune, should i take it seriously and try to RMA my HD?
Straight from HD Tune website
i have ran other tests thru WD utilities n it says it's fine but i'm kinda worried anywaysIf the parameter is highlited in red it means that the parameter has reached a critical value. In this case you should make a backup of your data and replace the hard disk.
b) Run the Error Scan
There shouldn't be any damaged (red) blocks. If there are you should backup your data and replace the hard disk.
