RMA from evga ...
waseem
I open an RMA in the EVGA CS , they decide to change the EVGA 780i ftw to the EVGA 790i ( not FTW ) the normal one . so whats better the 780i FTW or the 790i ( normal one ) ?
the meassege : the FTW 780 is not at stock so we decided to replace it with a 790i
yes i have the Corsair : 16Gb Kit (4G X4) CMZ16GX3M4A1600C9 CL-9-9-9-24
so dos the system run much faster ? or i get much more preformance ?
I really don't think it will run any faster or slower. The main difference is just the memory type. Your memory will run faster since it is faster memory.:D
No, not really. The only thing faster ram is good for is benchmarking.
I had 4 gigs ddr2 1066 on my old 775 board. I switched to 6 gigs ddr3 1600 with my first x58. I honestly couldn't tell a difference using the same gpu in either set-up.
C2Q to i7 made no real gaming difference either.
