faugusztin
- Mar 9, 2008
Hi,
i have a issue with my Fractal Design Define R3 - considering all i have is 1 SSD, i don't need any of the 8 3,5" positions, and would choose instead a better intake airflow (especially as i'm upgrading to Air Penetrators sometime soon).
There are 8 rivets securing this drive bay in place, 4 at bottom are no problem, they can be drilled out from bottom.
The problem are these 4 :
The rivet head is at top, but it is impossible to drill them out from there because that is only 2 drive bays (no space to do that). On other side, it is not easy from bttom either - the rivets are just 0,5cm from the side, and there is a divider 15cm bellow what can you see on photo. So what should i do to get rid of the hard drive cage ? What tool to use ?
Any ideas are welcome
