rivet size for lian pc-70
Abadon
hey folks any one got the specs on the rivet sizes used (both in diameter hole and countersink shamfer)
i just got my case back from anodizing, but i don't got a measuring tool that small
I am thinking there just normal 1/8th" rivets, I seen one of the computer parts stores that had aluminum rivits for sale, I looked and can't find them now, sorry.
Just Curious, how much did it cost to get your case done and where did you do it?
The correct rivets are AC4-3A (Marson brand rivet) Aluminum 1/8 dia countersunk rivet. I get mine from Grainers.
You can also use a AC4-2A if you have clearance issues on the backside of the rivet, same rivet as above just shorter
lol, and all this time I just thought they were all basicly the same! I took out the hard drive rack from my Gigabyte 3D Aurora and have been thinking about putting it back in, as the airflow was not increased like I thought it would have been, so I am also in need of finding the right Rivits for the job.
the anodizing went for 125 CAD at progressive annodizers and cutting was done for free because my friend works at a tool and die shop
