Rivatuner won't detect clock settings on second GPU
AMD_Gamer
I have 2 evga 9600GS0 video cards here in my folding rig, now the first card that has the monitor connected to it works fine with rivatuner it detects everything and i can overclock just fine.
The second card however does let me overclock with rivatuner, I can change the fan speeds and pretty much everything except in the overclocking tab it does not show any clock speeds and will not detect them.
Why is it doing this, the card is working fine and it is the same exact card as the one that works with rivatuner?
Pretty sure if you overclock one card, the other card receives the settings.
So don't worry about it lol.
I never declared official SLI support and I'm not gonna do itt and I will not buy SLI system myself just to satisfy impatiient SLI system owners. Want to get SLI supported - send me two similar cards and I'll do it. It is not a rocket science, it is a question of money I don't want to throw away for hardware configuration I absolutly don't need (and don't like).
RTFM definitively helps, quote from 2.11 release notes:
- Added experimental overclocking support for the secondary display adapters in Crossfire systems (only for Windows Vista).
There is no support for Crossfire overclocking in XP and probably never will be in future, readme more than directly informs you about it.
