rivatuner fan speed!?!?1?
i want to increase the fan speed of my gtx, so i installed rivatuner (newest version 2.06). however, when i run it, a window pops up about an unsupported driver (using current forceware). but thats not the problem. when i go to change the fan speed, it only allows me to change the performance 3d slider. when i apply the changes, it applies the change i made to all three sliders. see below, i took that screen shot while i was clicking and dragging the slider.
Please read carefully the first lines from the RivaTuner 2.06 release notes, especially the first lines under What's new.
ahh, so i guess maybe i should read the fine print a little more instead of just flying through installing programs right? :eek:
is there another program that will allow me to independently adjust those settings? thanks for the pointer
well, i have been avoiding ntune b/c i previously had it installed before i reformatted and it would dick with my settings for ultramon each time i rebooted, namely the smart taskbar. but i installed ntune and adjusted the fan speed there and it didnt mess with my ultramon settings
Yes, you can control the fanspeed with RivaTuner. A good guide here from boogieman, another guide is this. :D
Another thing that I forgot to mention is that the 8800 series don't have separate 2D/3D clock.
My favorite method is the auto fanspeed control, some reading for it, and another too.
Don't forget, that you have an offset of 7 gr.C between the ADT7473 IC and the G80 core sensor. ;)
After you figured out how it's working, you may be a happy RT user.
Forget the bullsh1t nTune, it causes more trouble than aid. Uninstall right away, do a regclean after, don't leave any track from it ! Believe me, I'm not kidding.
i will look into that on sunday, but unfortunately i have a test tomorrow morning. thanks alot
