Rivatuner and...
Does Rivatuner 2.09 work well with Nvidia Geforce GTX 260 with 177.41 drivers?
I downloaded it, BUT, at the beginning of starting it up, it says something like, "the detected driver is not supported by rivatuner, proceed with caution" every time.
I also cannot control fan speed for different performance levels, only overall fixed.
I don't want to screw anything up, I'm just wondering if anyone else has used RT with a GTX 260/177.41, and if OCing with it will still be O.K
Thanks
The current RivaTuner (v2.09) was released April 30th, that's before the release of GTX 260/280 so there's no support for those cards built in.
In other words, use it at your own risk.
The next version of RivaTuner is rumoured to release in mid August and should have support for the new cards (GTX 260/280 and HD 4850/4870).
Yes it works great, everything I have tried works
Overclocking, forcing clocks, manual and automatic fan control, etc.
What drivers are you using?
Also, right now I'm just using RT to monitor my temps...that can't hurt anything right?
Just set the option in that dialog that says "Do not show this again until I use a new unsupported driver" or something along those lines. It says that for me as well and I'm using the 175.xx's with an 8800GTS 512.
