RivaTuner/8800GT questions
NathanP2007
K so i JUST got my Evga 8800GT 512mb and 610 PC power and cooling PSU. I have the nvidia program that tells me my PSU and PCU temps but im not sure if they are totally accurate, and i want to see my graphic cards temp. I have riva tuner but i have NO clue how to use it to see tempuratures of my PC components, can anyone give directions or a website tutorial on how to view temps?
By the way, what are the perfect average temps for a AMD 5200+ X2 processor and my PSU and my graphics card? Thanks a ton guys.
Good tutorial, mine never goes higher than 60 degrees after I followed it. Make sure to click the enable background monitoring button so it works while you're gaming. If you read through the tutorial it shows you that you have to monitor Core Temps to set it up, so that's the temperature you want to look at.
nvm i see it showing the GPU temps, now i just need to find a reliable PSU and CPU temp showing program(s) anyone know of any?
