honestjohn
- Jul 28, 2004
Get it here ...
http://downloads.guru3d.com/RivaTuner-v2.2...wnload-163.html
Rivatuner Version 2.23:
What's new:
Added ForceWare 182.xx drivers family support.
Updated databases for Detonator and ForceWare drivers. Added databases for ForceWare 181.20, 181.22 and 182.05.
Added Catalyst 9.1 drivers family detection.
Updated PCI DeviceID database for NVIDIA display adapters.
Added reference fan duty cycle monitoring and low-level fan control tab for G92 based display adapters using integrated on-die fan controller (e.g. GeForce 9800GTX series). Please take a note that low-level fan control tab for display adapters using integrated fan controller is provided only as a workaround allowing you to control the fan if the drivers are completely unable to do it. It is strongly not recommended to use low-level fan control for integrated fan controllers if driver-level fan control functions properly.
Added heuristic driver version detection for unattached display devices (for example the secondary GPUs in SLI/Crossfire mode invisible to OS) under Windows Vista.
Improved driver-level overclocking and fan control for NVIDIA multi-GPU systems. Thanks to Jacob Freeman @ EVGA for providing GeForce 9600GT SLI system for new features development and debugging. Multi-GPU related
Improvements include:
Added optional independent driver-level overclocking and fan control support for display adapters working in SLI mode. Now RivaTuner provides independent driver-level overclocking and fan control by default for the secondary GPUs in SLI configuration. Driver-level overclocking and fan control on the primary GPU is still mirrored to all secondary GPUs joined into SLI configuration, however this behavior can be disabled via NVAPIMultiGpuClockControl and NVAPIMultiGpuFanControl registry entries if completely independent control is needed.
Ability to overclock and control fan speed at driver level for display devices unattached to windows desktop (e.g. display adapters dedicated for PhysX acceleration).
Improved hardware monitoring module
Improved print friendly monitoring graphs screenshot capture
Updated bundled RivaTunerStatisticsServer v3.1.0 utility
Minor skin appearance changes, "Normal" application detection level has been renamed to "Low" for better understanding.
Added pre-created profiles for 3D applications, which require non-standard On-Screen Display coordinate space settings (e.g. Codename Panzers : Phase Two and Alpha Prime).
Added pre-created profiles for new pseudo-3D applications.
Updated bundled D3DOverrider v2.0.0 utility
Fully redesigned user interface
Improved help system
