Hi
I just installed my new evga 8800 gt superclocked yesterday ,i was readin this post about how to make the fan run autmatically depending on temp by making some setting in Rivatuner ,This is a response from that post:
What I did was set the fan to change with different temps. If you want to do this, go to the power usuage tab then RivaTuner \ Fan and set AutoFanSpeedControl to 3. Then go to the Main tab then low-level system settings. I then used the settings of a [H] member to set the fan.
Duty cycle min = 34
Duty cycle max = 100
T min = 56
T range = 8
T operating = 110
T low = 0
T high = 110
I tryed to follow that but i could not change the numbers in low -level system setting ,it doesnt allow me to.
When i change to number 3 in autofanspeedcontrol it desnt give me option to apply
Any suggestions how to change to these numbers.
Thank you very much
Duty cycle min = 34
T min = 56
T range = 8
T operating = 110
T low = 0
T high = 110
Thank you very much
