snaggletooth
- Aug 16, 2005
Finally. I have been waiting for this feature to come out. Now if we only could get some voltage control...![]()
Not possible.
I am aware of this. It would just be nice if nvidia gave us at least some limited control of it. Oh well, there's always volt mods!
Which is also easily defeated by changing a couple of resistor values. Take a look over at VR Zone and what they did with the 8600 they got ahold of.
dammit! i posted the linky, someone's gotta go first here! like another poster, my shader clocks are already in the 'caution zone' with the triangled exclamation point and exceed 1500mhz.
someone giver a shot and exceed 1600mhz !![]()
WTF are you talking about caution zones and shit? Just use the settings and raise the max from 1500 to 2000 if you will, problem solved. Here's some caution zone for ya:
He is referring to the fact that RivaTuner's hardware monitor limits the shader clock graph to a max of 1500mhz thus flagging a caution symbol.
Nice OC Super, that your max or just one you tested at? Or is that your bios one from before?
lol, well damn, it's caution at default so i was a-scared! no need to get snippy![]()
Hehehehe, how much lower is 3dmark with the stable OC? Few hundred?
Can't wait to try out this and the drivers that were released today when I get off work =)
Just fu**ing with ya![]()
WTF are you talking about caution zones and shit? Just use the settings and raise the max from 1500 to 2000 if you will, problem solved. Here's some caution zone for ya...
Hey, what setting did you use on the shader clock, 2.52, 2.53? (RivaTuner 2.04, which I assume you're using.)
Is that artifact free though? I realize you can run furrycube, but what about the artifact scanner?
Snaggletooth, pretty nice OC on the memory. 1080 MHz on the 8800 GTS equals exactly the bandwidth of a stock GTX (900MHz), 86.4GB/s.
Where are you finding that monitor that shows your speeds for the shader core? I can't find it in rivatuner.
