Ritek Ri-Data Dual Layer + Rs
dR-Jester
How do these compare to Verbatim's? The Ri-Data's are so much cheaper but because of that is there any difference in quality?
Reason Im asking is because Im looking to make a huge switch to DL and the Ri-Datas are looking like a good brand because of their price. A little over a $1.50 (Ri-Data) as opposed to damn near $3 a disc (VB).
I'd suggest one of two things.
Check out club.cdfreaks.com for quality scans using your drive and the media to compare
Or, buying a _limited_ number of each and test them for yourself.
The variables are the media and its application. If this is meant for a settop box, then you really need to test out both types to ensure that they will play properly on your setup.
