Riser Card Question
Michigan PC
I'm looking for graphics solutions for a 2U server that I'm using as a desktop. The case only fits low profile cards. Is it possible to use a riser card so that I can use a full sized PCI-e 2 x16 card? Does anyone have any experience with that?
The card and motherboard won't be affected by using something like a 90 degree riser, however you'll have to make sure the card and riser physically fit in your case.
Contact the manufacture of the server. They often can tell you more of what you need regarding this.
