lifanus
- Aug 26, 2008
So, I notice some slight ripple going from top to bottom on my lcd2690 on dark tone areas... This only happen when monitor is hooked through DVI-D or DVI-I connections.
Tested with two different graphic cards, 9800gtx and hd4870, both shows ripple, ripple is visible on all different resolutions as well as different stretching method or 1:1 pixel. When monitor is hooked to my laptop through VGA connection no ripple is visible. Can someone tell me if this is more likely the monitor or my PC's internal components that's causing it?
