Ripping out LCD
TKEcowboy
See if you can find a datasheet for that LCD panel with power requirements, pinouts, etc.
Chances are you'll be buying a earthlcd.com controller to get it to work, and they're not cheap. I've yet to see a naked LCD panel that can take DVI or RGB.
Take it off of the metal bracket. Read off the manufacturer and part number (located on a sticker, probably).
Yeah, that's the right sticker, but I can't seem to find a controller board which supports that LCD (Fujitsu NA19019-C101). :(
