I have to listen to a few CDs worth of music for a class I'm taking but they can only be accessed via internet and streamed through realplayer. Is there anyway I can rip them to my computer and throw them on my mp3 player?
I'm not familiar with RealPlayer shit but have you tried downloading the playlist and opening it with Notepad? Should give you the URL of the media file if it's anything like a M3U file.
Other then that you could record them while listening.
Download a free app called Audacity, open it up and in the top right hand corner there's a drop down menu and you gotta select "Stereo Mix". Make sure the volume is kind of low so it doesn't clip and hit record then play in RealPlayer. Export as wav when you're done, encode the MP3, done.
