Any tips for cleaning the new parts I should get very soon?
I read about 50:50 Vinegar and Distilled water but I assume thats for extreme cases when you have build up. I think I will be fine with just flushing it with distilled water, but asking to be sure. Which leads me to my next question, the best way to do this, normally I'd put something under that tap and let it run, but since that is a big no no, I'm not sure how to flush properly with a gallon jug of distilled water. Should I use like a syringe/turkey baster or something into each part individually, or connect tubes and fill it like a leak test and then drain? Or should I just build it and leak test with distilled and see what happens? Do you bother using the coolant+water mixture for leak testing. I would assume you'd want to just to see the colored water if there is a leak somewhere, it will be easier to tell.
Anyways, thanks for the tips and infos as always. Will try to get this thing running soon.
