Right when I load WoW my computer restarts.
Rang
Right when I see that my character has reloaded, my computer restarts. I have tried with a 5900NU and 9800pro both have the same results. I'm using a fresh install of xp pro and have all the latest drivers/direct x. What could my problem be?
Well I've been using this setup for a month or so with no problems. My hd crapped out on me yesterday and I replaced that. So there shouldnt really be any hardware problems.
Yeah, apart from the HD crapping out...
Or maybe it's crapping out is a symptom of the same problem.
Its not malware don't listen to that cause if you did a clean load of XP there's no way for any type of adware/spyware to hit your pc... Try this ( Fresh install of windows XP again this time don't do no updates for windows are anything just load the game and CHECK FOR PATCHES and FIXES for the game and install your VGA drivers and try running it again) if it does it I would have to say its a motherboard... Just because random restart and sometimes I bet the machine does it for no reason as well... Try it and see what happens!
