How else would you do a one handed ctrl+alt+del?!?!?![]()
If you're doing CTRL+ALT+DEL to access the task manager, CTRL+SHIFT+ESC is faster (left hand, one-handed)
If you're mashing CTRL+ALT+DEL to restart the computer, you don't need the mouse anyways![]()
Now that I think about it, I havent touched either of those buttons in over 5 months. So no, I dont think I would.
I'm using it to login to a locked Windows XP domain computer... ROFL. I lock/login at least a dozen times a day.BTW, I use the ctrl+shft+esc for task mgr.
and win+L to lock... or win>L>L to logoff (assuming no other program is in the start menu that begins with L, hehe; i hate keyboards without the right windows key, lol, simply because i use it so much).
