Right Pentium Processor? NO FLAMING...plz
Your links are broken. What motherboard/processor are you looking at?
Yes they will work together. Although I highly reccommend getting a 2.8C. There is no noticeable speed difference and the 2.8E runs much hotter than a 2.8C. Plus the 2.8C is cheaper.
If you are bent on getting a 2.8e you should wait until Intel releases the Tejas.
Originally posted by chockomonkey
Will that motherboard work with the 2.8c? or will i need to find another one...
That board will definitely work with the 2.8c. I've had good experiences with the Abit IC7 and IS7 series boards.
Do you really need the Max3? The IC7-G and IS7 are very good motherboards as well, and perform very well, and are also less costly. I also agree that you should get a Northwood 2.8C instead of a 2.8E.
