Right angled PCIe extender that fits under a GPU?
Smoblikat
Hello all, im trying to locate a PCIe ribbon extension that I can have plugged in underneath a GPU (2 slot card covers both X16 slots....great design) and im not having much luck. I found this:
https://www.amazon.com/ADT-Link-90Degree-Extension-R11SL-TL-Extender/dp/B07TBMLKT3?th=1
Which looks similar to what I need, and I translated one of the reviews and it seemed like they said they were using it for a similar purpose as me (they also called it a tablecloth, so im not sure :p ) But that cable is (expensive) limited to X1 PCIe, which doesnt matter a ton especially since the board is PCIe 3, but I would like to use it for a GPU, so at least X8 would be nice.
Anyone know where I could find somthing like that?
Thank you,
Smoblikat
what about relocating the first PCIe slot instead, and looping the cable over whatever card you have the second slot?
Thats a really good idea, and would work, but the board is mATX, and I would like to stick to an mATX case, so if I used the ribbon on the first slot, and plugged the GPU in normally to the second slot, I would only have one PCI expansion slot left open for the second dual slot card, which would conflict with some of its I/O :/
