Right Angle SATA Connectors
For the most part you kind of have to beat the cable into it, I have one of these with the pins broken off and it works great for working the connector onto the cable.
Yea I got those very same connectors - I was told by the guys at Performance PCs that you just basically shove the wire into the connector with a flatblade screwdriver. Tried it and it worked for me just fine....
