Righ Click Menu?
Megalomaniac
question:
When you right click on a file, you get the menu witha few options.
how can i change those? add delete them?
Thanks
thaks for the guide, but i already tried it (and many like it)
these are very simple ones where as my undesirables were much more complicated.
but i found this!
http://www.nirsoft.net/utils/shexview.html
TO ALL:
do you guys want to get rid of that annoying "play in WMP" right-click option from the list?
get that program!
This program will allow you to enable and disable every type of context menu.
My new favorite program to control the unyielding windows OS right click menu options...
Edit:
found this link also
http://pcworld.about.com/magazine/2212p188id118255.htm
