Rig Review/Advice
Greetings,
This is my first time building a rig. I have selected some components but I’m not sure if they mesh together. I’m not looking for a performance machine but something that’s a lot better than the average PC. I won't be overclocking it. The focus is to be more on multimedia. It should be able to run Photoshop CS2 etc., edit movies and pictures, record TV, play the odd game like Oblivion and so on smoothly. I’m also looking at future proofing it to some degree. The current total runs to about $2,000. I want to slash another $1000 off it. I would be grateful for any suggestions and advice. Thanks in advance.
Case: Black Lian-Li PC-V1000B PLUSII V Cool Aluminum Mid-Tower ATX Computer Case, w/ Air Duct, 12cm Fans, EAR http://www.directron.com/pcv1000bplusii.html $182.99
Motherboard: GIGABYTE GA-N650SLI-DS4 LGA 775 NVIDIA nForce 650i SLI ATX Intel Motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E16813128044 $136.99
CPU: Intel Core 2 Duo E6600 Conroe 2.4GHz 4M shared L2 Cache LGA 775 Processor http://www.newegg.com/Product/Product.aspx?Item=N82E16819115003 $223.90 (Price drop in July?)
Memory: CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory http://www.newegg.com/Product/Product.aspx?Item=N82E16820145034 $91.00 Mail In Rebate Selection: http://www.newegg.com/Product/Produ...7+50001666+1052108080&name=240-Pin+DDR2+SDRAM
HDD: Seagate ST3750640AS-RK 750GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive http://www.newegg.com/Product/Product.aspx?Item=N82E16822148217 $249.99
CD/DVD Burner: SAMSUNG Black 18X DVD+R 8X DVD+RW 8X DVD+R DL 18X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA DVD Burner With LightScribe Technology - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151141 $37.99
Secondary CD/DVD Burner: LITE-ON Black 52X CD-R 32X CD-RW 52X CD-ROM ATAPI/E-IDE 52X CD Burner http://www.newegg.com/Product/Product.aspx?Item=N82E16827106061 $17.99
TV Tuner Card: Hauppauge WinTV-HVR-1600 MCE Combo ATSC and NTSC, PCI, Whitebox http://www.pcalchemy.com/product_in...nd-ntsc-pci-whitebox/cName/pvr-cardstv-tuners $89.95
Video Card: EVGA 320-P2-N811-AR GeForce 8800GTS 320MB 320-bit GDDR3 PCI Express x16 HDCP Video Card http://www.newegg.com/Product/Product.asp?Item=N82E16814130082 $259.99 Mail In Rebate (Comparison Reference: http://www.playtool.com/pages/vidtable/table.html)
Power Supply: Corsair HX Series CMPSU-620HX 620W Power Supply Retail http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=373110 $126.90 Mail In Rebate.
Cooling Fan:Thermaltake Blue Orb II CL-P0257 Cooler for Intel LGA775 and AMD K8
http://www.amazon.com/o/ASIN/B000BW...&pf_rd_t=101&pf_rd_p=291314101&pf_rd_i=507846 $37.50
External HDD: Seagate FreeAgent Pro 500 GB USB / eSATA / FireWire 400 External Hard Drive ST305004FPA1E3-RK
http://www.amazon.com/Seagate-FreeA...3?ie=UTF8&s=electronics&qid=1181747068&sr=8-6 $199.99
OS: Windows Vista Ultimate Edition $358.99 / Ubuntu
Total Cost: $2014.17
If you're doing more multimedia work than gaming, a Q6600 should suit you better. It'll be $266 in july. Also, if you won't be going SLI, get a P965 or P35 board instead.
I would reccomend 2 smaller hard drives than 1 750gb one and why don't you get two Lite-On DVD drives?
Or get two Samsung SATA drives. Screw ever having an IDE cable in the machine.
Agreed with the hard drives. You can get a 7200.10 Barracuda 500GB for... $120 I think? From the egg. 2 is still cheaper than that 750gb and you get 250gb extra.
Definitely agree. If you're not reusing any older optical drives, you can now consider IDE cables works of Satan and buy SATA drives. You'll be 100% thrilled that you did. Plus you can burn 2 DVD's at the same time if you wanted. Couldn't do that with 2 opticals on the same IDE cable....
Also... buy an OEM version of Vista, http://www.newegg.com/Product/Product.aspx?Item=N82E16832116213 it's only $189.99. Or if you have an old copy of XP, and don't like OEM's, get the Upgrade for $229
Absolutely on all counts. I haven't used an IDE optical drive since Plextor released the 712SA and I haven't looked back. I have two copies of Vista Ultimate and they are both OEM copies. $200 is reasonable for an OS in my mind, $400 isn't.
