TheMuffinMan
- May 10, 2001
Hello all. I've been trying on and off for the last couple of days to install Windows 3.11 on a 486DX running a fresh install of DOS 6.22 off of an industrial flash memory module. The problem is that the Windows install keeps stopping when the second disk is inserted. After much futzing about, re-imaging floppies and hair pulling I've discovered the true problem.
When a floppy is first inserted and the directory structure probed, everything works fine. When that floppy is then removed and a second put in its place, a DIR command yields the directory structure of the first disk. The same problem occurs no matter what disk is put in after the initial one, the first directory structure is always listed.
Thus far, I have removed SMARTDRV from the autoexec.bat file on the offchance that the drive caching feature was causing the problem. The problem occurs even after going to the C: drive an running various operations, the returning. Even with no disk in the drive, a DIR command will yield the first floppy volume label before throwing a read error.
Any help or suggestions would be greatly appreciated.
