Riddle me this... Dead MB or Dead CPU???
scootchu
I have a Asus A7V333 MB and a brand new Athlon 2200 that was shipped to me several months ago under an RMA. I had a meltdown about 8 months ago and sent the MB to ASUS and the CPU to AMD. The MB was returned to me with ASUS saying that it was fine and AMD much to their credit sent a new CPU.
Everything was working just fine for about 3-4 months and I was using the setup as a HTPC, never a hiccup. I had only used the rig to watch DVD's on my HD and the other night I setup a recording overnight and when I came home from work I flipped on the TV and there was "American Chopper" frozen on the screen with the digital sound "Gagagagagagagagagagagagagagagagagaga". It wouldn't respond to anything so I hit reset and the CPU posted and started windows and then the screen went black. No worries, I will start in safe mode as I had been messing with resolutions prior to this, no go on the safe mode. I have forgotten what command it stopped at, but it was a full page down. Okay I figure my OS has been compromised, I have no problem reinstalling. I get out the XP and it loads the drivers and then gets to "setup is starting windows" and freezes there forever.
Okay, now I am a bit more concerned as I see $$$ being flushed. I take everything out except the CD, and HD and change out the RAM. BZZZZZZZ nada, same thing. Now I change the display card, nope, HD? nope. I can f/disk and format, but no go on the load of XP. Maybe 2000? Nope same thing. Ewwwww, Windows Me? Yes, but it was getting late and I stopped when I couldn't find my serial, God I hope I never have to use Me, so who cares.
Finally I take the CPU and reseat and nothing changes, I take the CPU over to my other MSI Delta MB and I get the white bar load of windows and then black. Now I figure it's the CPU, BUT is this common to exhibit this startup problem and XP/2000 install freeze????
I thought that if a CPU posted you were free and clear, obviously I could be wrong. My feeling is the MB has voltage issues and cooked one CPU a while back and now has damaged this one. Could I be correct? Should I send the Athlon back to AMD or is that taking advantage of them? I wasn't about to try my 2700 in the Asus MB, so I don't know if it would boot or install windows. Any help would be appreciated!!!!
