Rhythmic chirping from Zalman VF900
Z
Zinn
Guest
I think that's what the cooler is anyway, it's the low profile cooler with the heatpipe. You know, the one everyone was ape shit over a few months back. Anyway, I've been noticing increasingly this rhythmic chirping coming out of it. How do I know it's that fan and not one of several others in my case? Slowing the VF900 down slows the chirping down.
My guess is that one of the bearings in the fan is going south, which leads me to my question. I'm running a 7600GS purely for productivity, I don't do any gaming on it whatsoever. If I were to just disconnect the fan and keep the heatsink on (passive) do you think I would bake my card eventually? I would prefer not to do any baking, and I'm not sure what the temperature tolerances on these GPUs are.
Thanks for the help.
Okay it was driving my crazy, so out of desperation I disconnected it. Temperatures are stable between 47-50 celcius. Can I go to sleep and leave this thing on?
You'll be fine, provided you don't game in a hot room.
I'm actually surprised with the 7600 GS: most models out right now have an active fan, although when it was released, it was touted as an inexpensive, passive-cooled solution.
You probably can cool the 7600 GS with the vf900's fan off. The vf900 is a beefy heatsink, and the heatpipes really help its performance.
