RGB problems
Psycrow
I got G skill trident royal ramm (The silver ones)
And then i have Thermal take case fans.
The G skill memory uses Asus armoury crate to set the given RGB mode. Then i set em to default rainbow.
And the case fans uses TT rgb plus software that recently got updated.
Now i see my memory and other rgb units connected to the motherboard dosent work. My rgb units are stuck on the colours and dosent move like static.
Also i have this littel display on my motherboard Asus extreme deluxe XIII and this display also freezes up now.
I have the memory and the display and a led strip connected. When i reboot my pc and windows loads up then everything works fine until TT rgb plus has loadet up.
Then all these units becomes stuck and static.
If i exit TT software and opens the asus software, then these 3 units works fine. Until i reboot or opens the TT software again.
It use to work fine until the recent TT software update. I tryed to uninstall it and installed the old tool again but it seems like the damage was done...
I tryed to fix this reinstalling both softwares and it dident work.
Im out of idea
