Moogle Stiltzkin
- Nov 11, 2004
I calibrated my Dell 2405 FPW lcd monitor RGB to meet the
color temperature of 6500k, gamma 2.2 and luminance 220
This is my result
OSD settings to achieve the targets above are the following.
red 17
green 22
blue 50
Brightness 90
Is it correct that blue should be left as the default 50 out of 100 ? and i only adjust red and green only ?
Im new at calibrating so my concern is why the blue in the screenshot is higher then the rest, is this acceptable ? also with the delta score is it alright ? Contrast seems to be very very low. This monitor should be capable of 1000 contrast.
Source: http://www.drycreekphoto.com/Learn/monitor_calibration.htm
When the calibrator reads actual rgb, i adjust the osd rgb to meet the target rgb in the calibrator software. Does the rgb in osd for monitor need to be even as well ? or does it not matter as long as the calibration rgb is met?
Any help ?
This is my result
red 17
green 22
blue 50
Brightness 90
Once you have the screen levels set, the Red, Green, and Blue guns need to be balanced so neutral colors do not show a color cast. Do as many of these adjustments by using your monitor's display controls as possible (don't worry, your calibration software will give details on how to do this). Adobe Gamma or any of the hardware calibration packages can do everything by adjusting your video card alone, but the result is a reduced color gamut for your display. This is not good, as you will clip the purest, most saturated colors.
Any help ?
