so as soon as i figure out which T-froce to put the QP, i plan on putting my old asus mobo back into the aria and using it as a file server of sorts. Looking at making it as quiet and as cold as possible since it will be constantly on along with my QP.
Available parts:
asus a7n8x vm/400
thermaltake slim volcano 10+
corsair platinum pc3200 512mb
Need to buy parts:
xp-mobile 2400+ 35w or 45w @stock (would like to undervolt but cant with this board)
seagate 5400rpm 40gb or
a notebook hard drive
a 5.25 multi function panel (temp/fan controller)
what fan replacement would you guys recommend for the psu? Looking for something thats as quiet or quieter with much much more airflow.
Is there a correct way to install that damned optional fan bracket?I put the rail on like psu just like the instructions said to but the rest of the parts (L bracket, tube, long screw and thumb nut) are like wtf? I figured i could micky mouse it but i wanted to see if there was an absolute correct way to stick a 80mm fan onto it? I want to remove the fan off the volcano and use a quieter 80mm or 92mm fan attached to the rail.
Lastly, are there any mounts or enclosures to securely place a notebook hard drive into the 3.5 drive bay?
Available parts:
asus a7n8x vm/400
Need to buy parts:
