Review? Opinions?
Uggh. Premod... If you want a good case, that looks sorta like that, get a Chenming 601/602, and put leds in the grill, give it a nice paintjob, etc. It will look better than that X-Fireball though... ;) Or, you could put lightstrips on the edges of the front bezel...
okay, I don't understand what the hell is wrong with you people. All I ask for his for some info on the case, I don't give a shit about your opinion on the case or how it looks or whatever, deal with other peoples likes and dis-likes. It's not always that easy for find reviews and such on cases ya know.
Ok, If you like premods (do you?), that case is the bomb. And then, even if you don't like premods, you can mod that thing even more... (change of LEDs, etc...) So, sorry if I sounded rude there, I was just trying to get you to see, that that isn't exactly the best, and YOU yourself, can do a better job of modding. I'm putting faith in you. If you have a problem with that, then fine, be that way...
I'm sorry man, I guess I'm just a little on edge from working so much. The thing about the case is, its for a system I'm building for my brother, so I showed him a couple sites and this is the case he liked and wants, so I'm just trying to see how good it is with airflow and such. I understand about modding and such but I've never done it before and don't really have a lot of time to do it anyways, premodded would be fine. The case doesn't have to be THE best, either.
That's okay. Also, I can't tell whether it has any vents, but that side fan probably will give a lot of airflow. Plus, that thing is cheaper than most premod cases, and looks a lot better. And, I'm no expert, but, if you really want to, I'd say go for it...
The Only Thing The Case Has Going For It Is Its Looks. You Barley Get Any Air Flow They Way The Case Is Setup. Your Temps Will Run About 110 - 115 F. You Want To Look For A Case That Has Fans In The Front To Move The Air In From The Front And Out The Back So The Air Moves Over The Components And Not Have The Hot Air Just Swirl Around In The Case.
This Case Would Be Good If You Are Planning On Water Cooling.
Edit: Even Though It Says There Are Fans In The Front There Are No Intake Holes On The Front So The Fans Just Recirculate The Air Thats Already In The Case Instead Of Pulling In New Fresh Cool Air.
You Always Want The Back Fan(s) To Blow Out Because If They Blow In They Just Bring In The Heat Of The Psu.
