1. What will you be doing with this PC?
Gaming, compiling C++, Python, Java, running SQL (University IT student work)
2a. What's your budget? $500
2b. Are tax and shipping included in this budget? NO
2c. Is your budget flexible? Slightly, within $100
2d. Is cost a driving factor in component selection? YES
3. Where do you live? Do you have any big B&M (brick and mortar) computer chains nearby (e.g. Microcenter, Fry's, etc)?
FL. There is a local CompUSA
4. What exact parts do you need for that budget?
CPU, RAM, GFX, MoBo, Case, Optical Drive, possibly PSU
5. If reusing any parts, what parts will you be reusing?
80mm/120mm fans (regular height)
HDD1: Western Digital Caviar SE WD2500JS 250GB 7200 RPM SATA 3.0Gb/s 3.5"
HDD2: (unknown) 250GB 5200 RP SATA 3.0Gb/s 2.5" from gateway p171x-fx laptop
6. What specific features do you need in a motherboard?
Required:
Wireless b/g/n
MITX form factor
Want:
USB 3.0
Bluetooth
Upgrade potential
7. What resolution output do you need?
1080p for gaming current and some future titles. Single monitor only
8. Does this system need to fit into a particular space?
I am using a shelf in a sliding door closet as my desk, and I tend to move at least once per year. The smaller, the lighter, the better.
9. How comfortable are you with custom case design/modification and electrical wiring?
Have screwdrivers to work on desktops and laptops and light duty trucks!
Have power drills/dremel.
Have tinsnips/wire cutters.
NO soldering tools.
NO electrical experience. (unless baking my laptop counts as a solder reflow)
10. How important is the noise/silence of this system?
No high pitched whining, please. There is a toddler here that provides as much of that as I can stand. Fans OK (generally don't care)
11. How mobile does this system need to be?
Mobile/light enough not to break my back lugging it to/from my truck when I move. Won't be leaving the desk on a daily or even monthly basis.
12. Do you already have a legit and reusable/transferable OS key/license?
32 and 64 bit WinXP Pro, 32 bit Vista IDKWTF distro. Maybe I'll try Linux
13. When do you plan on building/buying the PC?
Immediately. I baked my Gateway P171x-fx laptop and got about 2.5 weeks out of it before it failed again; just enough to finish out the semester. My backup PC is older than the laptop and has 8 blown capacitors on the mainboard that I'm just not comfortable fixing myself. I can't keep limping along on dying hardware (don't tell my truck, PLEASE!), so I planned out the following. I'm not brand loyal, but I'd prefer to keep away from nVidia if possible.
NewEgg Wish List Link: http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=17449986
For those who wish not to click:
AMD Phenom II X2 555 Black Edition (planning to unlock extra cores)
G.SKILL 4GB 204-Pin DDR3 SO-DIMM (PC3 10666)
MSI R6850 Cyclone PE Radeon HD 6850
ASUS M4A88T-I Deluxe
LITE-ON DVD Burner DS-8A5S
Slimline SATA to SATA+molex adapter FLT-6020-18
SILVERSTONE Sugo SG05BB-450
EST price: $600+tax/shipping
Will the SG06's 300w PSU be enough, can I mod it to take my old full ATX psu, and if I do, will I need an aftermarket cooler? Answer: Swapped for the SG05 with a 450w 80+ Bronze PSU at the same price. Increased efficiency over the previously mentioned, now removed, 70% efficient 520w PSU results in similar expected output. Aftermarket cooler unnecessary.
Is there hardware I should switch out? I need to buy within the coming week, but I'd like to leave myself room to upgrade over the next 3 years as funds become available, and I'm already $100 over budget.
Required:
Wireless b/g/n
MITX form factor
Want:
USB 3.0
Bluetooth
Upgrade potential
NO soldering tools.
