Reversing power supply bracket on V2000
aNoMaLy2k8
Hey guys,
Wondering if you could help me out really quick - I've finished my i7 build with this case but when I was in the midst of installing it, I discovered that the intake fan on the power supply would only face the top shelf in the case that separates the lower chamber and the motherboard area or the bottom of the case - which has a radiator there now...
So, I was wondering if any of you have run across this and what you did about it.
Cheers,
aNoMaLy2k8
You could always pull the PSU apart and reverse the fan. I believe the fan up in front of the hard drives pulls air in so reversing the PSU fan would make sense.
What I did on mine...
Flip the PSU bracket upside down so the intake is on that 'shelf'.
Remove the shelf (drill out the rivets).
